12-01-2019 03:46 PM
12-01-2019 09:16 PM - edited 12-01-2019 09:21 PM
Greetngs,
FW updates are periodically pushed out by Canon and are normal. Not upgrading or delaying won't keep you from using your printer.
There are a few things missing from your post.
What is the model of your printer?
What OS are you using?
Start with the following:
Perform maintenance, a nozzle check pattern. What are these results.
Are you seeing colors, without gaps or spaces?
If no, perform a head cleaning and retest.
If yes, then the printer is probably operating normally and you might have an incorrect setting in the print driver or application you are printing from.
11-22-2020 03:29 PM
I have the same problem. My screen is constantly telling me that a firmware update is available from the website. Interesting. NOW WHAT? I go to the Canon website and search "firmware update for G4210 printer," and get no results. It's been very frustrating.
I have a MAC X 10.10.5 and the printer is a G4210
My biggest problem with the printer is its connection to the computer. Very slow scanning and printing, and often I get the message, "the image failed to scan."
Can new firmware help, or will it make my problems worse?
Any help would be appreciated.
