05-01-2020 01:18 PM
I am using a Canon iP8750 and around 1 in 3 prints are ruined by dust (ink not hitting the paper so leaves a white spot).
I am trying to be as careful as possible, keeping the paper boxed and loading just before printing. I am also inspecting the paper and using a dust blower shortly before the paper goes through to try and remove anything but it still happens.
How can I eliminate this?
Thanks
05-01-2020 03:53 PM
Hi jamiek,
The IP8750 is neither sold nor supported in the U.S.A. You've reached support for Canon U.S.A. If you require support outside the U.S., I recommend contacting the branch of Canon for your region. You may find the correct website using the map on the Canon Global website: http://global.canon/en/support/
