07-16-2013 08:14 PM
I have a Cannon printer and I have a problem when trying to print. Everything prints out faded when I choose standard settings, but when I choose photo print, then high resolution, it prints the picture out perfectly but takes a very long time. Im printing out a lot of brochures and trying to find a faster way to print this with good quality. Where do I start?
07-16-2013 09:19 PM
Hi Chargersrool,
So that the Community can help you better, we will need to know exactly what operating system you're using. Any other details you'd like to give will also help the Community better understand your issue. We look forward to hearing back from you!
07-17-2013 10:04 AM
Operating system is windows 7
07-20-2013 08:10 PM
Hi chargersrool,
The iP2770 is designed as a casual use printer, and as such the standard setting on this model would be comperable to draft on others. This is intended to save ink when you are not printing anything of major importance. As you have alerady noticed, the resolution to this would be to choose a higher quality setting which does slow down the printer.
