Reply
Highlighted
Frequent Contributor
Accepted Solution
Can the Pixma iP8720 print on 230 gsm 61 lb paper?
Can the Pixma iP8720 printer feed & print 230gsm/61 lb 8.5x11 paper without rejecting or jamming? Been using this paper to print photo covers for soft cover photo books on an Epson WF 30. I need a better printer and I'm 99% committed to buying this Canon Pixma iP8720 if it can print on this heavy paper.
Thanks, Russ
Highlighted
Re: Can the Pixma iP8720 print on 230 gsm 61 lb paper?
Hi brassman,
The PIXMA iP8720 can use plain paper that is 17 to 28 lb (64 to 105 g /m2) (except for Canon genuine paper), and non-Canon genuine specialty paper that is up to 53 lb (200 g /m2).  We do not recommend using paper that is lighter or heavier than these paper weights in the printer, as they may jam or do damage to the printer.
For printers that can handle up to 61 lb paper, we recommend our Professional Photo InkJet Printers.  These printers can handle up to 93 lb (350 g / m2) when using the manual feed tray of the printer.
Hope this helps!
Highlighted
Thanks Ramona. I ordered the PIXMA iP8720 yesterday anyway and before I received your reply. Well, I'll try the 61 lb photo paper and see what happens. Is there a warranty on this printer?
Thanks
Highlighted
Hello.
The warranty period is for one year from the original date of purchase.
Highlighted
New Contributor
brassman, I realize it's been a while but I'm in the same situation as you were. Did the ip8720 work with 230 gsm paper?
Highlighted
Yes it did. I was referring to Office Depot "Professional Photo Paper" 61 lb/11 mil 230gsm Matte double-sided paper. No problem.
powered by Lithium
