12-02-2022 07:56 PM
Need to get an updated driver for the Canon LBP6230dw printer for the mac os ventura 13.0.1 software version.
12-03-2022 07:58 PM
Maybe some help here.
12-03-2022 03:56 AM
Visit the support page for your printer.
Canon Support for imageCLASS LBP6230dw | Canon U.S.A., Inc.
~R5 C (1.0.2.1) ~RF Trinity, ~RF 100~400, +Canon Control Ring
~6D2 (v1.1.1) Retiring ~EF Trinity, others ~DxO PhotoLab Elite ~Windows10/11 Pro ~EVGA RTX 3080Ti FTW3 Ultra ~ImageClass MF644Cdw ~Pixel6 ~CarePaks Are Worth It12-03-2022 06:53 PM
Thank you. I am still unable to get my MacBook Pro to recognize the printer. I have tried installing and reinstalling. The printer has an IP address on my lan and shows on a list when installing but I cannot print to it. Can't figure out what I am missing.
12-03-2022 07:58 PM
12-05-2022 12:33 PM
Thank you so much. Your advice did the job. I was able to accomplish the task of reconnecting my Mac to the printer. Awesome!
12-03-2022 08:05 PM - edited 12-03-2022 08:09 PM
You know the IP address of the printer.
Apple menu > System Preference > Printers and Scanners
Select the printer, remove it using the (-) minus option.
Now select (+) to add. Don't use Bonjour, or Airprint... Select the IP icon above. Enter the printers IP address. In the second field below, change the name to something meaningful to you. "LBP6230dw" or similar. There is another drop down below, this where you can select the driver. Since you have already installed the Canon software, the driver will be one of the selectable options in the dropdown list... Next to add. It should add and appear with a green ready dot.
Not from Ventura, But looks similar
~6D2 (v1.1.1) Retiring ~EF Trinity, others ~DxO PhotoLab Elite ~Windows10/11 Pro ~EVGA RTX 3080Ti FTW3 Ultra ~ImageClass MF644Cdw ~Pixel6 ~CarePaks Are Worth It12-07-2022 05:56 PM
I'm having this problem too. I don't see a driver option for mac os ventura.
12-07-2022 10:10 PM
The first file listed here is the setup tool and the second file is the printer driver for the LBP6230dw printer.
https://www.usa.canon.com/support/p/imageclass-lbp6230dw#idReference%3Dsoftware-drivers
01-02-2023 02:34 PM
I've tried everything I can think of and that has been suggested. I keep getting "filter failure" when I try to print. I couldn't get the second file to download. I'm currently running Monterey 12.6.
01-11-2023 08:31 AM
Is Monterey 12.6 the most current OS version available? I don't see it on the list for driver updates.
