11-04-2023 09:56 AM - last edited on 11-04-2023 09:57 AM by Danny
I want to be able to print without having to enter a department ID or PIN. I also want to use the Remote UI. I don't mind using a PIN for the Remote UI, but I want to get rid of department ID and PIN. I can't seem to do both for some reason.
01-30-2024 04:24 PM
Hello RandyD123,
You can change the settings from the remote UI so you do not need to enter the department ID to print. You can use the steps in the link HERE to log in and change the settings. You will see a list of items that you can set to need the id or not. If you continue to have problems changing the settings, you can contact sup[port over the phone at 1-800-652-2666. Our agents would be happy to help.
