imageCLASS D420 windows 11 driver???
ffejvt
Hello.Just purchased a new Dell tower and am bummed that my trusty imageCLASS D420 will not work with windows 11(at least i don`t think as i cannot find an 11 driver.Much obliged if anyone knows a way i can get them to communicate.BIG thanx!
3 ACCEPTED SOLUTIONS
jalloway
I'm running into the same issue.  HP has the new drivers posted on their website - why doesn't Canon?
Hector
To use the D420 with a Windows 11 computer, you can download the Windows 10 drivers and software using the link found HERE. The drivers will work with your Windows 11 computer.
YESSSS Hector.i figured that out last week.works like a charm.THKU soooo much for reply man!
12 REPLIES 12
jalloway
Hector
Hi Hector - thanks for the reply.  I am able now to connect to the printer with a USB cable, but through my wired network.  Is there a factory reset procedure so I can reset all of the network features?
This did NOT work for me.
Windows 10 drivers do not work for me on a Windows 11 HP Pavilion, installing as a local printer.  Printer installs but does not print test page, nor a Word document. Document just stays in print queue.
Addition by JustDon: My problem has been solved.  Here is what I think I did wrong.  First, I had the printer plugged in to the PC and turned on when I ran setup.exe to install the drivers.  Second, I tried to install it in LPT1, the parallel port when it needs a USB port.  With the drivers improperly installed, there was no choice of a USB port.  Properly installed, a port named USB001 was added to the port list. An aside:  I read that some older printers can't run on the new high speed USB ports, but after I installed it in a USB 2.0 port, I moved it to a "super speed" usb port and it worked fine.  So yes, the ImageClass D420 can be installed on a Windows 11 PC (mine is a HP Pavillion) using the Windows 10 drivers, as Hector said, but if you don't install them correctly, you may mistakenly conclude it won't work.
I tried that link several times. Installing, uninstalling, shutting down the computer restarting, etc. The windows 10 version did not work on my new Windows 10 HP All In One computer.
Sorry, I mean Windows 11 computer.
11/22/2022: New firmware available for EOS R3, EOS R7 and EOS R10
10/14/2022: Help ensure your autofocus is properly aligned with a Canon Precision Alignment
09/19/2022: New firmware version 1.0.4.1 is available for EOS C70
07/28/2022: New firmware version 1.2.1 is available for EOS-R3
07/21/2022: New firmware version 1.6.0 is available for EOS-R5
07/21/2022: New firmware version 1.6.0 is available for EOS-R6
07/21/2022: New firmware version 1.1.0 is available for EOS-R7
07/21/2022: New firmware version 1.1.0 is available for EOS-R10
07/01/2022: New firmware version 1.3.0 is available for PowerShot PICK
06/07/2022: New firmware version 1.0.3 is available for EOS M50 Mark II
04/26/2022: New firmware version 1.0.1.1 is available for EOS R5 C
02/07/2022: New firmware version 1.6.1 is available for EOS-1DX Mark III
01/05/2022: Welcome to CES 2022!
