09-23-2017 03:11 PM
Hello,
The printer in question is iR C5235A
I am printing 2 copies of the same image side by side. My color setting are all proper since when printing a single image, it appears exactly as intended, when I try to print 2 side by side; left side comes out perfect and right side is oversaturated and looks much warmer, and it prints a yellow vertical line about 1cm off paper edge.
When I flip image upside down, same happens execept other way around 😄
Printer itself was calibrated multiple times using machine's internal settings. The fact that first image prints beuatifull convinces me it is set right.
But why for crying out loud it changes on the other side of sheet.
Using original Canon toner.
Thanks for all help in advance.
09-23-2017 03:19 PM
Hi, chartkor!
Thanks for posting! While our forum community members are welcome to chime in, Canon does not provide direct support for imageRUNNER series products. Instead, your dealer will be able to help you! If you don't have a dealer and you're in the United States, please call us at 1-800-OK-CANON (1-800-652-2666) and we will be happy to provide you with the names of dealers in your area.
If you're outside the USA, visit http://global.canon and choose your country or region from the map for local support.
We hope this helps!
