05-06-2024 12:04 PM
Last week I set up my new GX2020 printer and it works great! Love it. However when I tried to set my own administrator password to use the GX2020 UI, I could not. The GX2020 manual says the default password should be the printer serial number. That did not work. The manual also says I should see a "REMOVE ADMINISTRATOR PASSWORD" message on the printer screen. That option does not show up. I tried to just enter a new password and that did not work either. Hoping someone can help....
11-15-2024 12:24 AM
It updated and then somehow I was able to print out settings and it allowed me to use the serial number from the printer utility to reset the password.
05-06-2024 12:11 PM - edited 05-06-2024 12:12 PM
The default password should be 9 characters. The printer's serial number. 4 letters + 5 numbers.
05-06-2024 12:13 PM
My printer serial number is 9 characters - 4 letters and 5 numbers. Didn't work. Thanks anyway, Rick
05-06-2024 12:38 PM
New printers come with a 1yr warranty and free installation support. If the default password isn't working, I'd reach out to Canon.
05-06-2024 12:52 PM
This might help: https://support.usa.canon.com/kb/index?page=content&id=ART171716
11-14-2024 11:32 PM
I am having the same problem with the password neither cannon or the serial number would work .
Went to the front panel tried to put in a password there now it's all screwed up reset admin password is nowhere to be found in the menu. Printer is working otherwise I just can't adjust setting from the utility on the PC because it wants a password. the link is of no help as it takes you to virtual assistent with a limited selection of problems it can handle and passwords is not one of them .
11-15-2024 12:24 AM
11-15-2024 12:26 AM
It updated the firmware while I was playing with it and I was able to print out the settings which said it had no password. Then I was able to use the serial number in the utility and reset the password.
