MAXIFY MB2720 Only Copies Half Page
Wei
Printing is fine but when I copy only half page
1 REPLY 1
Hector
Hello Wei,
If your copies are only coming out as half a page, it could be caused by settings or there is something wrong with the scanner bar. You can try resetting the settings using the steps below. If you still have the same issue it would usually mean the MB2720 needs service.
  1. Select Setup from the home screen.
  2. Select Device Settings.
  3. Select Reset Settings.
  4. Select Settings only.
  5. Select yes.
We would be happy to assist with the issue. To provide some feedback or some troubleshooting steps, we would need some additional information. If you could reply to this message with the information below, we can provide some assistance.
  1. What size is the original item and what size paper are you printing on?
  2. The half that does not appear, is it black or is that portion blank?
