Magenta Ink Canon G7020
Pwilson1
I have had the Canon G7020 for about a year.  It won't print the magenta ink even though it is full.  I have done all
the maintenance they suggest and have also reset the printer and updated the firm wear.  Any ideas on what could
be happening?
1 REPLY 1
Mijayhawk
I had the same issue with the magenta ink and tried the deep clean but that did not do the trick this time.  After some research, I tried the Ink Flush from the operational panel.  It solved the issue and is now printing all colors.  You have to make sure all your ink containers are full before starting the process because it does use a large amount of ink.
Avatar
