MFC624cw end of cartridge life
624cw
is there a way around the end of cartridge life error.  only the magenta toner appears to be out so i should be able to print in black and white.
2 REPLIES 2
Stephen
Moderator
Moderator
Welcome to the Canon Community!
The Community isn't intended for immediate assistance. If your question is urgent, contact support at 800-OK-CANON (800-652-2666), Monday through Friday from 9am to 8pm (ET).
If you're outside the USA, please click HERE for support options.
Hector
Hello,
If you get a message that the toner has reached the end of it's lifetime, you can continue to print, but you can run into issues with the print quality. When the message comes up, you can select the option on the display that says continue printing (quality not guaranteed). You can use the steps found in the link HERE to select that option.
