10-08-2015 02:11 PM
Hey
For some reason my mac laptop(OS X Yosemite) won't detect the MF8080Cw printer anymore. The weird the thing is, it works sometimes but I would have to delete the printer from system prefrence > printers & scanners and add it again. But now it won't detect it anymore. I also tried reinstalling the driver and my co-workers can all use it fine so it might be something with my computer but im not sure. Did i miss a step?
rhonjo
10-08-2015 02:48 PM
I also tried connecting directly via usb cable and it detects it fine but it still won't print and it gets stuck when its sending the data to print
10-08-2015 03:00 PM
Hi, rhonjo!
Thanks for posting on our forum! This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, contacting our US-based technical support team is the most efficient way to get these issues straightened out. They're standing by, ready to help 24/7 via Email at http://bit.ly/EmailCanon or by phone at 1-800-OK-CANON (1-800-652-2666) weekdays between 8 AM and 8 PM ET (5 AM to 5 PM PT).
Thanks and have a great day!
10-27-2015 04:45 PM
Hi Rhonjo.
If you still need assistance with this issue, I will be able to assist you.
I recommend uninstalling and reinstalling the driver. To uninstall the driver, please follow the instructions below:
1. Open [System Preferences] -> click [Print & Fax].
2. Select the printer you are using -> click [-] icon.
Note:
Delete all print queues set from the driver you are deleting.
3. Delete the folders and files for the driver you are deleting.
Important
If you delete a "PPD.gz" file other than that of the printer model you want to delete, the printer driver may not work correctly.
Note:
If the [Authenticate] dialog box is displayed, enter the administrators name and password -> click [OK].
4. Restart your computer, and then empty the Trash Bin.
Next, download the MF Printer Driver, under the "Recommended Downloads" section, from the link below:
imageCLASS MF8080Cw - Drivers & Software
After installing the driver, please add the printer back to the queue by following the instructions below:
