04-16-2021 05:36 PM
My MF743Cdw suddenly stopped printing. The message at the bottom of the display says:
"Performing auto clean fixing assembly" and it just keeps saying this - it doesn't go away and it doesn't complete.
When I send something to the printer it shows up in the status queue on the remote UI as "Waiting" but never prints
The printer is a few months old and has printed almost 3,000 pages already.
I did put non-canon cartridges in it a few weeks ago but it's print printing just fine since then and the "Canon Genuine Mode" is Off.
I couldn't even shut it down by pressing the power button - I had to unplug it. But when I plugged it back in I was in the same situation.
Any thoughts?
11-29-2021 04:18 PM
Thank you. After turning off Auto Clean Fixing Assemby I was able to print a test page. Harvey
04-23-2022 04:03 PM
Same issue with an MFP743 ... none of the solutions presented has worked so far...
06-26-2022 02:37 PM
Thank you! this worked for me on a MF741C dw
02-03-2023 11:34 AM
David,
Thank you for posting this. I tried everything you had tried prior to seeing this post. This worked immediately. It is screaming of a SW bug in the system. However, now I am good and able to use the printer completely.
Scott
04-14-2024 01:51 PM
Thank you!!! This worked for me after trying everything else for hours, this simple fix worked within seconds. I signed up just to give your answer a thumbs up to push it up the list to hopefully help others with the same issue.
07-14-2024 06:49 PM
This worked! Thank you!
And thank you to Canon for establishing and maintaining community website - since user manuals are useless.
08-19-2024 07:23 PM
Copy and cancel worked for me too. Brilliant workaround!
10-05-2024 12:22 AM
To force the printer to power down, hold the power button down for about 10 seconds and it will exit and shut down.
