MF632Cdw Toner Spots
pgmerik
I LOVE THIS PRINTER; however I just started getting toner spots in MAGENTA color.  I have now immediately changed the toner cartridge, but the spots continue.  Can you please forward the proper steps for cleaning the items that I need to clean on my model as was done in another stream for a different Cannon model.
THANKS
Erik
Patrice
Whiz
Hi pgmerik.
It is recommended that you perform a fixing unit cleaning and transfer belt cleaning.
Note that you cannot clean the fixing assembly when the machine has documents waiting to be printed.
To clean the fixing assembly, you need plain A4 or Letter size paper. Set the paper in the paper drawer or multi-purpose tray before performing the following procedure.  Loading Paper in the Paper Drawer   Loading Paper in the Multi-Purpose Tray
1. Select <Menu> in the Home screen.
2. Select <Adjustment/Maintenance>  <Maintenance>.
3. Select <Clean Fixing Assembly>.
4. Check that the size and type of paper displayed on the screen is loaded in the machine, and select <OK>
5. Select <Start>.
 Cleaning starts. When a message appears notifying that cleaning is complete, press  to return to the Home screen.
Transfer Belt
To clean the transfer belt, perform the following procedure. Note that you cannot clean the transfer belt when the machine has documents waiting to be printed.
3. Select <Clean ITB>.
4. Select <Start>.
 Cleaning starts. When a message appears stating that cleaning is complete, press  to return to the Home screen.
If the issue is not resolved with the cleanings, then please call us at 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays).
6 REPLIES 6
Patrice
Whiz
Hi pgmerik.
5. Select <Start>.
Transfer Belt
4. Select <Start>.
New cartridge and these cleaning steps WORKED!!!
Thanks
Erik
I have tried this so many times and it says cannot cleaning fixing assemble or ITB why? I am following the directions
Same here. "could not perform cleaning"
Those maintenance steps did not help clear up the magenta streaks/banding on my My MF632Cdw laser printer. Anyone know what to do about that?
ted939
I'm having the same problem on my MF632Cdw laser printer, but the magenta is big horizontal streaking of magenta bands. Anyone know what to do about that?
