01-06-2022 03:14 PM
I think this started with Windows 11 but my Duplex setting defaults to "Off". I then do not get the option to print double-sided. I fixed it the other day but it is back to "Off" again. I just did a reset of the settings on the printer and it started as "Off", this did not happen before. I just removed the printer and added it again and I can set it through Windows but it thinks I need to do it manually now.
Please help, this was working perfectly before.
01-07-2022 08:24 AM
Hi, fluvius!
Thanks for posting on our forum! This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or register your Canon gear HERE to access additional support options.
Thanks and have a great day!
01-07-2022 10:33 AM
Thanks, I downloaded the Canon drive and it fixed things up: https://www.usa.canon.com/internet/portal/us/home/support/details/printers/color-laser/color-imagecl...
Thanks!!
01-06-2022 03:40 PM
Now, I think I have fixed the Duplex issue but my print jobs just sit there. I was able to add the printer after removing it but it won't print the jobs. I tried using my phone and it worked but not on my Windows 11 PC.
01-07-2022 08:16 AM
It's official that it resets itself after a restart. the only solution I have is to remove the printer and add it again every time I need to print. It looks like the printer kept the setting "On" this time.
Canon, please help!!
01-07-2022 08:24 AM
Hi, fluvius!
01-07-2022 10:33 AM
Thanks!!
