10-15-2024 11:10 AM
I've been using this printer for years. I upgraded to Ubuntu 24.04 and can no longer print. I get:
MF416dw: File \"/usr/lib/cups/filter/pstoufr2cpca\" not available: No such file or directory
When I select the printer in settings, I get a storm of "Bad driver information file" errors.
Investigating led me to something... interesting:
joliver@blinky:/tmp/canon/linux-UFRII-drv-v600-us$ apt list | grep cups | grep residual
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
cndrvcups-common/now 4.00-1 amd64 [residual-config]
cndrvcups-ufr2-us/now 3.60-1 amd64 [residual-config]
joliver@blinky:/tmp/canon/linux-UFRII-drv-v600-us$ sudo apt-get install cndrvcups-common cndrvcups-ufr2-us
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Package cndrvcups-common is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
cndrvcups-ufr2-us
Package cndrvcups-ufr2-us is not available, but is referred to by another package.
cndrvcups-common
E: Package 'cndrvcups-common' has no installation candidate
E: Package 'cndrvcups-ufr2-us' has no installation candidate
10-15-2024 11:35 AM
So, I didn't realize those were old Canon drivers. I removed them with dpkg -P
10-15-2024 11:37 AM
joliver@blinky:/tmp/canon/linux-UFRII-drv-v600-us$ sudo ./install.sh
This installer is recommended for the following distributions that are currently supported as of the release of this installer:
- Fedora/Ubuntu/CentOS/Debian/UOS/Kylin OS/NeoKylin OS
If this installer is run under distributions for which the support period has ended, the installation of additional system libraries may be necessary after driver installation is complete.
Note that an internet connection is required for installation.
Do you want to continue with installation? (y/n)y
# Install Start
Machine Type = amd64
Package Type = deb
Package list =
./x64/Debian/cnrdrvcups-ufr2-us_6.00-1.02_amd64.deb
# Install Package Check
OK: cups
OK: cups-bsd
# apt-get update
Hit:1 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:2 http://archive.ubuntu.com/ubuntu noble InRelease
Get:3 http://archive.ubuntu.com/ubuntu noble-updates InRelease [126 kB]
Hit:4 https://packages.mozilla.org/apt mozilla InRelease
Hit:5 http://security.ubuntu.com/ubuntu noble-security InRelease
Hit:6 https://esm.ubuntu.com/apps/ubuntu noble-apps-security InRelease
Hit:7 https://esm.ubuntu.com/apps/ubuntu noble-apps-updates InRelease
Hit:8 https://esm.ubuntu.com/infra/ubuntu noble-infra-security InRelease
Hit:9 https://esm.ubuntu.com/infra/ubuntu noble-infra-updates InRelease
Get:10 http://archive.ubuntu.com/ubuntu noble-updates/main amd64 Packages [592 kB]
Get:11 http://archive.ubuntu.com/ubuntu noble-updates/main Translation-en [144 kB]
Get:12 http://archive.ubuntu.com/ubuntu noble-updates/main amd64 c-n-f Metadata [10.2 kB]
Get:13 http://archive.ubuntu.com/ubuntu noble-updates/universe amd64 Packages [697 kB]
Get:14 http://archive.ubuntu.com/ubuntu noble-updates/universe Translation-en [206 kB]
Fetched 1,776 kB in 2s (1,056 kB/s)
# apt-get install libcups2
Note, selecting 'libcups2t64' instead of 'libcups2'
libcups2t64 is already the newest version (2.4.7-1.2ubuntu7.3).
0 upgraded, 0 newly installed, 0 to remove and 108 not upgraded.
Replace: libcups2 -> libcupsys2
# apt-get install libcupsys2
E: Unable to locate package libcupsys2
NG: libcupsys2
NG: libcups2
# apt-get install libcupsimage2
Note, selecting 'libcupsimage2t64' instead of 'libcupsimage2'
libcupsimage2t64 is already the newest version (2.4.7-1.2ubuntu7.3).
NG: libcupsimage2
OK: libgtk-3-0
OK: libjpeg62
OK: libgcrypt20
OK: libjbig0
OK: lsb-release
Some system libraries could not be installed.
Refer to the Readme file for more information.
Do you want to continue with installation? (y/n)Searching for libcupsys2 turns up some really old posts suggesting it should be installed with libcups2
11-15-2024 12:39 PM
Hey Jnojr -
how were you able to resolve this?
