Reply
Highlighted
New Contributor
Re: MF Toolbox doesn't work on Windows 10
Way back on page 3, message 23, Piers_A  's message fixed my problem scanning with a D530.  Thank you so much!
Highlighted
Occasional Contributor
I think this problem is for imageclass printer. What series is that?
Highlighted
New Contributor
D530.jpgIt's an imageCLASS D530.  It's a few years old, printer, copier, scanner.  It's been a great unit.
Highlighted
New Contributor
I have a Canon ImageCLASS MF8380Cdw combo printer scanner; I've had it since 2012.  The scanner worked through many Windows10 updates right up until May 2019.  When I tried to scan something through MF Toolbox I got the message "A supported scanner cannot be found".
CANON  SOLVED THE ISSUE WITH A WORKAROUND -- but I cannot find again the Canon post to which I can add this reply.  Here's what I did that had no affect on the problem: 1) uninstalled the software program, 2) reinstalled the software program, 3) went to Canon website and downloaded all updates for: firmware and drivers and the scanner patch for the 8380
None of the above efforts fixed the problem.  Then I came across the Canon workaround thank goodness because I can't find it again.  Here what worked for me as I followed Canon's instructions:
> Right click on the Canon MF Toolbox 4.9 icon
> Left click on "Properties" at the  bottom of the window
> Select the "Compatibility" tab at the top right corner of the window
> Select the "Change settings for all users" tab at the bottom of the window
> Select "Run this program as an administrator" at the bottom of the window
> Click "Apply" and then "ok"
My first attempt at opening the MF Toolbox worked without getting the error message and I was able to use the scan toolbox as I have always used it in the past.
THANK YOU CANON
Highlighted
New Contributor
That option is acceptable if you want your users to run as Admins on the desktop.  In our environment, we don't.  CANON seriously needs to update this software to keep up with Windows 10's latest releases, or else I'll be forced to go back to HP.
Highlighted
New Contributor
Using the patch has worked on all but one computer, which is also the only one using x86 Windows 10. Strangely, scanning on that computer worked well until two/three weeks ago. Did anyone face a similar problem and sorted it out?
I've tried multiple variations of the possible solutions here described, but with no satisfying results. The only "solution" that worked is to run Toolbox as administrador, but that doesn't allow scanning directly from the device.
Highlighted
New Contributor
Had not used the Imageplus D530 for scanning for a quite long time. When tried to use it today and ran into the problem described in this message group. I tried a few approachs described in the group and none of them worked. Eventually, I took the reset approach and it is working now. Let me list the step I took to reset the D530 installation.
1. Disconnect D530 from the computer
2. Uninstall MF Toolbox
3. From the device list, remove D530
4. Go to Canon support site and downloaded both D530 driver as well MF Toolbox
5. Installed the MF Toolbox and D530 driver
6. Connect D530 to the computer.
After connecting D530 to the computer, I found that it was automatically added to the device list. From then the scanner started to work.
Did not try variations of the reset approach such as the order of the steps.
Highlighted
[ Edited ]
Is there a real solution to this?
I've uninstalled/reinstalled several times.  I even installed the patch file listed, AND set the properties to run as Admin..
I have Windows update TURNED OFF, for this very reason.  I've been screwed over by MS enough to know better.  None of the listed KBs are on my pc anyway.
So... After working great for 5 months, suddenly I started getting the folloiwng error on my ImageClass MF4890dw
The tool box is...
No amount of patching, reinstalled, adjusting, or even screaming at MS has fixed this.
Is there a "real" solution anywhere?  I hate think that MS sabatoged my MF4890 and gotten away with it...
Highlighted
New Contributor
is NO REAL solution !
But you can check my solution with virtual machine and Windows 7. For me work perfect for 2 years and I made thousands of scans.
You will find solution one page back on this thread...
Have a nice day,
Dan
Highlighted
New Contributor
Re: MF4570DN - wireless scanning issues MF Toolbox doesn't work on Windows 10
I have a MF4570DN - I cannot get the wireless scanner to work on my Dell laptop running Windows 10.  I can wirelessly print and fax from my laptop; but cannot scan wirelessly.  (I have an older personal Toshiba laptop running Windows 10 and can scan wirelessly from it)
The Dell is a corporate laptop and I login to a corp domain.  They may have some things locked down, but are trying to assist in getting this to work. The latest software, MF Toolbox is loaded, the latest scan patch is installed by our IT dept.  What am I missing to get the wireless scanner to work? Is there something that needs to be configured differently?
I am working from home on an ATT wireless network.  The printer is hardwired to the router.
I appreciate your assistance very much!!!
powered by Lithium
