Reply
New Contributor
Re: MF Toolbox doesn't work on Windows 10
thanks...this worked beautifully!  and it was easy to do.
New Contributor
I had Windows 10 installed and everything was working properly until Windows 10 update 1511 took place couple days ago.  The scanning function did not work anymore after MF Toolbox was update to 4.9.1.1.
I uninstaledl both Canon driviers and MF Toolbox 4.9.1.1 and re-installed both from the original cd and everything is now working fine!
New Contributor
I also Same Problem in my Offic Printer. So please give me suggestions.
Geek Assured Tech Support in USA
New Contributor
As I said before, if MF Toolbox does not work after Windows 10 1511 update, that's how i solved the problem after few hours of frustration.
Highlighted
Occasional Contributor
IT WORKED!!! Simple, easy!!! AWESOME!!!
Thanks Captret and Piers_A Smiley Happy
My workhorse is back online!
Re: MF Toolbox doesn't work on Window 7
Can print or fax. Can also use Windows fax and scan. MF tool box dialog box not accessible. Cannot install or uninstall MF toolbox 4.9. Installation/Unintallation cmd not responding. Can do it in safe mode but still has no dialog box access.
dcp
I finally called the Canon Tech Support help line. The Toolbox software was being installed in the wrong folder. The agent on the helpline quided me through the process to fix the problem. Now everything works as before.
Me too, printer is 216n. Four calls to Canon tech support did not solve the problem. MS did not find any problem with my PC OS.
Toolbox 4.9 not working with mf216n.
Not a solution. Cannot scan from Toolbox 4.9.. Cannot scan from auto feeder into .pdf.
powered by Lithium
