11-18-2019 03:22 PM
Hello, suddenly my MB5420 won't scan via wireless or via USB. And documents are printed but stay in the print queue. I've deleted the printer and reinstalled it. Still NO scan. Still print queue messed up. Help please.
11-23-2019 11:02 AM
Same error message, with or without antivirus / firewall, etc.
11-23-2019 11:21 AM
OK, once I deleted the document that remained in the print queue after printing -- that still is an issue -- AND turned off the Malwarebytes AND Windows Defender -- I was able to scan. HOWEVER, I STILL NEED THAT PROTECTION!
11-25-2019 01:34 PM
Hi, clawsonrbc.
If the scanner worked with the av disabled, then you may be able to restore function by adding the relevant exceptions to your security software. A list of common ports may be found at the following Canon Knowledgebase article:
https://support.usa.canon.com/kb/index?page=content&id=ART174139
Refer to the security software's support for directions on adding exceptions.
Regarding the print queue, if it is not updating, check that Bidirectional Printing is enabled. You may find it through the following steps:
If it is already checked, then the print queue not emptying should be corrected by adding the relevant exceptions to your security software. If this is the case, click Cancel or OK to close the Printer Properties window.
If you need immediate assistance with this issue, please call us at 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays).
