02-13-2023
04:50 PM
09:55 AM
My MB2720 says blue ink is nearly full, but the blue is coming out as light pink (meaning, I assume, no blue is coming out). I did a regular cleaning, no change. Maybe I should just chuck this ink canister and try a new one? (Yes, it's a cheapo third-party ink canister, not official Canon.)
03-01-2023 02:39 PM
Hello Rafflbilek,
If the cyan is not printing, you can try 2 regular cleanings and a deep cleaning if the regular cleanings do not work. Some third party tanks can cause problems with the ink flow and can cause clogged print heads or blank portions in the print. They can also cause ink tank level detection issues. If the cleaning and deep cleaning did not resolve the issue, I would suggest replacing the cyan ink.
02-14-2023 09:36 AM
Hi, raffibilek!
So that the Community can help you better, we need to know exactly which Canon printer model you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
02-14-2023 09:46 AM
MB2720
03-01-2023 02:39 PM
Hello Rafflbilek,
03-05-2023 09:23 AM
How do you replace the ink if it's not empty yet?
