05-20-2021 12:47 AM
05-20-2021 10:42 AM - edited 05-21-2021 09:29 AM
I've not seen an MF series laser report low toner at 40% remaining, so my first question would be are you uasing Canon branded toner?
If yes, try removing the toner and holding horizontally, shake gently from side to side. You may want to do this outside as it can sometimes be messy. This can help redistribute the toner inside the cartridge evenly.
~R5 C (1.0.3.1) ~RF Trinity, ~RF 100~400, ~RF 100~500, +RF 1.4x TC, +Canon Control Ring, BG-R10
~6D2 (v1.1.1) Retired ~EF Trinity, others ~DxO PhotoLab Elite ~Windows10/11 Pro ~EVGA RTX 3080Ti FTW3 Ultra ~ImageClass MF644Cdw ~Pixel6 ~CarePaks Are Worth It07-08-2021 03:41 PM
Hello RhondasCanon,
The warning message will come up depending on what is set for the toner percentage in the Display Timing for Cart Prep setting. You can adjust that setting using the steps in the link provided HERE.
