09-13-2014 05:47 AM
LBP6000 doesn't work after upgrading to OS X 10 yosemite (beta)
Any suggestions? Solutions?
10-18-2014 02:28 PM
I just upgraded to Yosemite (I assume it is no longer Beta), and my Canon LBP6000 stopped working. If anyone has a suggestion, I'd like to hear it!
10-20-2014 11:26 PM
Hi smukhi and knipprs!
I will be glad to assist you. The driver is now available for the commercial release of the OS X 10.10 (Yosemite) driver. I recommend uninstalling the previous driver before installing the latest driver. To uninstall the driver, please follow the instructions below:
Location | Files and folders to delete |
/Library/Printers/Canon/ | CUPSCAPT |
/Library/LaunchAgents/ | jp.co.canon.CUPSCAPT.BG.plist |
/Library/Printers/PPDs/ Contents/Resources/ | Delete all the following files in the folders. CNMCxxxAUS.ppd.gz (xxx is a model name starting with [LBP].) |
When the [Authenticate] dialog box is displayed Enter the administrator's name and password, and then click [OK]. |
1. Click the [Printers & Scanners] icon in [System Preferences].
2. Click [+].
3. Click [Default], and then select the printer to be used from the printer list.
4. Select [Select Printer Software] from [Print Using].
5. Select the printer to be used from [Printer Software], and then click [OK].
6. Click [Add].
7. Make sure that the printer to be used is displayed, and then close the [Print & Scan] dialog box.
The printer registration is now completed.
I hope this information is helpful to you. Should you need further assistance, please contact us at 1-800-OK-CANON (1-800-652-2666).
10-28-2014 10:39 AM
I just downloaded the new 3.67 Driver but I can't find my printer LBP6000 When I want to add the printer, What should I do?
09-20-2015 12:36 AM
i am having the same problem when i get to step 8, of the first instrucions i reboot the computer. it starts up and i download the driver and when i try to install i get this error
canon capt printer driver can't be installed on this disk.A later version of canon CAPT printer driver is already installed. and i get the harddrive symbol and a driver symbol
Macantosh HD Mac_CA...0_us_EN
360.85 GB available 16 MB available
499.25 GB total 30.7 mb total
