Error message that transport cover on my GX4020 is open, but it isn't
Ed8
I recently set up my new GX4020 Tank printer and tried to load and print cardstock using the flat bed feeder.  First, I got a message that the paper was not loaded, so I selected print anyway.  Then I receive an error message to check the transport cover that it may have been removed.  That is not the case, it is securely inserted.  Both the main cassette and rear paper trays work OK with no error messages.  Could it be that my cardstock is too thin?  It will feed through and print ok using the rear paper tray.
4 REPLIES 4
Alienna74
Hi, I have the same kind of issue on the GX4050.
I want to print cardboard from the rear tray.
I get the support code 1263.
I don't understand this error keeps coming, even the transport cover is in place.
What to do?
Thanks for joining the conversation, Aleinna74! We appreciate the info, though we need to let you know that the MAXIFY GX4050 is not supported by our team here at Canon USA since that product isn't available in this country.  If you live outside the United States, please click HERE and select your country to find support in your part of the world.  Your fellow Community members are still welcome to offer their advice.
Thanks for choosing Canon!
Moderator
Moderator
Thanks for joining the conversation, Ed8!
This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or register your Canon gear HERE to access additional support options.
Thanks and have a great day!
Hello,
The issue could be caused by the thickness or size of the cardboard. We would be happy to assist, but we would need some additional information to assist further. You can reply to this message with the information below and we can provide some troubleshooting steps or suggestions. For a more immediate resolution I would suggest contacting support over the phone at 1-800-652-2666. Our agents would be happy to assist.
1. What size is the cardboard?
2. What is the weight and thickness of the cardboard?
