02-13-2025 03:20 PM
I have a Color imageCLASS MF753Cdw printer connected wirelessly to my in-house network. If I am in another room and send a print job to the printer, i first have to walk into the room, wake it up, go back to my computer and send the print job. It would be my expectation that the mere task of sending a print job to the printer would "wake it up" and print the job. Is there a setting which either allows this to happen, or maybe even disables the "sleep mode" that would allow me to send a job to the printer without having to wake it up first?
02-13-2025 03:52 PM
I have both of my lasers connected wirelessly to different networks. Both sleep after a few minutes. However, both of my devices wake and print when a job is sent.
Does your printer have a static IP assigned?
Tell us more about your wireless network? Hardware, brand and model, etc. Also, are you using the printer with Windows, Mac or the Canon print app on a mobile device?
02-19-2025 03:56 PM
Since the printer does not fail to print all the time while on sleep mode, I will accept the solution of making this a static IP address and see if it goes. If i have an issue beyond this, i will start another thread with additional details. Thank you for your suggestions
02-13-2025 03:52 PM
02-15-2025 04:15 PM
my wireless connection is provided by Comcast.
02-18-2025 02:25 AM
This is what I suggest. Reserve the IP address your router xb7, xb8 or xb9 has assigned to the printer. Whichever model you have. You'll need to log into your router to do this. Look at the list of attached devices, Then reserve or assign the IP. You only have to do this one time.
Next step. I'd use the Dell laptop as a test device. Start by removing the printer. The next step is important, restart your computer. Now re-add the printer as an IP printer. If you don't know how to do this, just let us know.
Now perform a test print. Now use the Moon icon to put your printer to sleep. Now send another print job. What are the results?
02-19-2025 03:56 PM
02-19-2025 05:42 PM
Thanks for the reply. You can reply back here if The issue is not resolved. 🙂
