10-01-2023 01:21 PM - last edited on 10-02-2023 01:21 PM by Stephen
Same problem. Using MacBook Pro running Sonoma 14.0 with wifi connection. Error code is 10,202,3. My Canon is mf624cw.
10-02-2023 09:39 AM
Additional info. Canon MF Scan Utility allows legible scanning through its Photo and ScanGear options. The Document, Custom and E-mail options produce the error message 10,202,3 and illegible images.
12-19-2023 01:17 PM
Hello Marsh,
If you have updated to Mac OS Sonoma, you can download the latest version of our drivers and utilities to resolve your issue. You can download and install the updated version of the MFprinter/scanner drivers and utilities from our site using the link HERE. Once the new driver and scan utility are installed, you will be able to scan normally.
10-03-2023 04:59 PM - edited 10-03-2023 05:00 PM
I have the same problem with my Canon MF645C when I try to scan to PDF:
An internal error occurred. Restart the computer, then try again.
Code:10,202,3
Scanning to PNG or other formats works. There is probably a bug in the transformation of the scan into PDF.
I use the Canon MF Scan Utility Version 1.10.13 (1.10.13)
10-06-2023 10:01 AM
There's a driver update available that fixes this. Software and Drivers
