imageCLASS MF656Cdw Unable to remove toner tray to change cartridge
Emily6
This is the first time that I need to install/change the toner, but I cannot remove the toner tray. The blue bar is missing. Has anyone else had this problem?!?
1 REPLY 1
Stephen
Moderator
Moderator
Hi there!
Totally get the panic—printer issues on a weekend are the worst! 😅
The good news? Your printer is likely fine. In almost every case, the handle isn't missing; it's just tricky to spot.
Two quick things to check:
  1. The Door: Make sure you have pulled down the entire front face of the printer (grab the sides!), not just the small manual feed flap. If you only see a small slot, you need to open the "Big Door."
  2. The "Missing" Blue Bar: If the blue cosmetic clip popped off, the handle is still there—it's just black now. Give the center ridge of the tray a firm pull.
Check the Official Manual: This page has a clear diagram showing exactly how to open the main front cover (Step 2) to reveal the toner tray: Canon Online Manual: Replacing Toner Cartridges
Hang in there! If you're still stuck, our support team is back Monday morning at 1-800-OK-CANON.
