07-18-2021 09:48 AM
The printer worked fine until recently and when I try to install now, it is not recognized by the OS. I am running Chromebook Version 91.0.4472.147 (Official Build) (32-bit) Where do I get a new PPD file for installation of the printer?
08-04-2021 02:47 PM
Hello NorthHill,
To connect the printer to your Chromebook, you will use the connection for Mopria compatible printers. We do not have a PPD file to suggest installing for the printer. You can connect the printer to your Chromebook using the steps found in the link HERE. It will show which models support the Mopria option and how to connect.
