Canon imageRUNNER ADVANCE C5535i - Linux/ARM driver
AdamK
I'm trying to setup Canon imageRUNNER ADVANCE C5535i on Raspbian Linux (ARM architecture). I'm using CQue driver, which works fine on other Linux distributions under i386/x64 architectures. I can get the PPD files - that is OK. However, the "sicgsfilter" filter distributed with CQue for linux is compiled for i386/x64 and therefore unusable on ARM. Where can I get the filter (or the whole CQue package) compiled for ARM?
Thank you!
1 REPLY 1
Moderator
Moderator
Hi, AdamK!
Thanks for posting! While our forum community members are welcome to chime in, Canon does not provide direct support for imageRUNNER series products. Instead, your dealer will be able to help you! If you don't have a dealer and you're in the United States, please call us at 1-800-OK-CANON (1-800-652-2666) and we will be happy to provide you with the names of dealers in your area.
If you're outside the USA, visit http://global.canon and choose your country or region from the map for local support.
We hope this helps!
Avatar
