07-26-2018 10:31 AM
The printer is a Canon Imageclass D530 which is 1 year old. It prints just fine. I have never been able to get it to scan.
I press the Copy/Scan button
It says "Select the Scan Type". "Computer" is highlighted so I press the OK button.
It says "Select Scan Type". "Color Scan" is highlighted so I press the OK button.
It says "Scanning". I down arrow to "Confirm Destination" and press the OK button.
It says:
"DESKTOP-SNOKA8O"
"Color Scan"
Nothing is highlighted. Pressing the OK button doesn't do anything. Pressing the start button doesn't do anything. I'm stuck here.
I have also tried Custom 1 and Remote Scanner. Should I try MF Toolbox?
Can anyone direct me?
08-03-2018 07:33 AM
With the help of Canon support, I installed MF Toolbox and now the scan is working.
07-27-2018 09:48 AM
Hi projecttoday,
Do you have the MF Toolbox software installed? If not, it can be downloaded from Canon's website at www.usa.canon.com. Try scanning using the steps when you click HERE.
If you continue to have difficulties, please contact our support group using the following link:
http://Canon.us/ContactLI
07-27-2018 10:16 AM
Thank you. I was unable to find the download for MF Toolbox on the site. Can you provide the specific link?
08-03-2018 07:33 AM
09-13-2018 03:39 PM
I have a Lenovo computer with Windows 10 64Bit and I have installed the D-530 software and drivers. When I try to scan from the i push scan and select to computer. There is a pop up on the screen that asks me to select a destination for the scan. The box in the pop up is empty of any destinations.
I have loaded MF Toolbox and the application states my printer/scanner is not supported.
Is there a solution? I have removed and reloaded MF Toolbox.
I have searched for ScanGear and no dice.
I have downloaded and installed the drivers from Canon and the printer prints and copies but will not scan.
Any help is much appreciated.
04-04-2020 09:28 PM
Test the printer function from the computer..
