Reply
Occasional Contributor
wide angle converter
Hi everyone,
Can anyone recommend me a wide angle converter with decent quality of x0.43 or x0.5x for a canon lens with 52 or 58 filter diameter? I know a lot of them are very soft .
Thank you.
Forum Elite
Re: wide angle converter
"Can anyone recommend me a wide angle converter with decent quality..."
Simple, quick answer,... NO !  Don't waste your money.
Esteemed Contributor
Rather than convert your existing lens, it would be much better to get an EF-S 10-18 lens, you can probably get a good deal on a refurbished one:
https://shop.usa.canon.com/shop/en/catalog/ef-s-10-18mm-f45-56-is-stm-refurbished
for $240.
Let's say I want to convert a 50 mm lens to a 21.5 mm lens (0.43x) and take advantage of the shallow depth of field.
Forum Elite
Same answer.  Simple, quick ,... NO !
"Don't waste your money."
ok. Thank you.
You can't get a wide DOF with a wide angle lens.
I used a depth of field calculator.
An f/1.8 50 mm lens with a subject at 3 m has a DOF of 2.8 - 3.2 m
An f/1.8 21 mm lens with a subject at 3 m has a DOF of 2.3 to 4.3 m
Even if you got one of those expensive anti-Teleconvertors that *increase* the aperture number with a wider fov, if the resultant 21 mm lens had an f/1.0 aperture, the DOF would still be 2.6 to 3.6 m.
I think you mean a shallow DOF not "wide".
Correct me if I'm wrong, but I think that by mounting a WA converter in front of a 50 mm lens (let's say at aperture 1.8), I'll get only a wide angle of view not a deep depth of field. Think of an anamorphic lens.
Best.
I think you only get that with something like a Metabones Speedbooster*, not a wide-angle attachment.
*But that has to attach between the lens and the body.
Maybe you can try something like this:
http://ryanbrenizer.com/2011/05/brenizer-method-instructions/
powered by Lithium
