11-02-2015 11:54 PM
iam using canon 1200d, iam very interested in macro photography, iam confused in buying wether extension tubes or useing reverse lense or closeup filters
help me to gt right one
11-03-2015 04:06 AM - edited 11-03-2015 04:07 AM
Reverse lenses, extension tubes, and close up filters are not really macro photography. I've never tried to reverse a lenses, but it seems like it is more trouble than it is worth to me. Extension tubes and close up filters will cause your camera/lens setup to lose the ability to focus to infinity, which really doesn't matter if you're focusing on stuff very close to the camera.
You will never get true 1:1 magnification with any of those approaches. But, depending upon what you're photographing, you may not need to. For me, macro photography has meant taking close-up pictures of finished plates of food. I don't really need 1:1 magnification for that application. I just want the plate to fill the frame.
If you want to get serious about macro photography of the very small, and 1:1 magnification, then purchase a true macro lens. The EF-S 60mm macro lens would be a good choice for the 1200D. There are also two 100mm macro lenses, which could be better choices than the 60mm because ot the longer focal lengths.
11-03-2015 10:54 AM
While not totally correct, Waddizzle's reply is generally right on.
I have seen some pretty impressive 'macro' photography with reverse lenses. IMHO, too, it is a pain to get right and a real macro lens is better, in most cases.
Extension tubes simply alter the focal point of a lens. In other words it lets it focus closer to the camera. Sometimes even touching the front element.
At Hallamrk we always used macro lenses. Never any other close focus gimmick. If I were going to get back into this hobby, there is no doubt which lens I would get. The Canon EF 180mm f/3.5L Macro USM Lens. It is unbelieveably sharp a real jewel in macro photography. It is worth saving for it need be. My second choice and one I recently sold, is the Canon EF 100mm f/2.8L Macro IS USM Lens. Avery good lens in its own right, too. Plus is is a little more affordable.
Save your money for the tubes and reversing stuff and put it towards one of these lenses.
11-03-2015 12:55 PM
@ebiggs1 wrote:While not totally correct, Waddizzle's reply is generally right on.
[ save space}
As usual, your tastes lean toward the state of the art. What do you think about the MP-E 65mm f/2.8 1-5x Macro Photo lens?
11-03-2015 06:29 PM
[ save space}
A magnificent piece of glass but I would be afraid to get that as a very first macro lens from what I've read. It does nothing but macro. It can only focus by moving the lens closer or farther from the subject. DOF is razor thin. You probably need focus rails almost all the time? But then I am probably more cautious and conservative about new things than some.
I plan to get a macro lens but I believe I'll start with a 100mm Canon or maybe a 150mm from a 3rd party.
11-03-2015 11:22 PM
thank u for ur suggestion
but iam very poor, if i need to get lense like u said i need to wait for more than 3 years save money for that
my salery is just $200 per month
any other suggestion please
11-04-2015 10:02 AM
"As usual, your tastes lean toward the state of the art."
What can I say, the best is the best. Unfortunaltely it costs money.
"What do you think about the MP-E 65mm f/2.8 1-5x Macro Photo lens?"
I can not comment on the MP-E 65mm f/2.8 1-5x Macro lens because I have never owned or used one. I have used the EF 100mm f2.8L and the EF 180mm f3.5L. I try to hold "my recommended" comments to lenses I 'personally' own or use.
I have sold all my macro gear because I have little interest in it any longer.
I would never consider buying a macro lens under 100mm because of the working distance. That is the big reason I discount any macro lens under 100mm without personal use or testing. The MP-E 65mm f/2.8 1-5x Macro may be a fine lens! It is not for me!
Sometimes is is cheaper to start with the best instead of maybe buying lesser lenses and then finding out you want the better lens anyway. Buy the best and cry once is an old photographic saying.
The EF 180mm f/3.5L Macro USM Lens is a duo purpose lens as it makes a great medium tele. It has the disadvantage of only a f3.5 max aperture (most lenses in this range offer f2.8) but it offers f32. Give to get? It is ultra slow to focus so a sports lens it is not.
