10-04-2019 07:35 AM
Hello everybody
i have problem in my lens ( canon 16-35mm 2.8 II ) the edge be a blur and not clear in left and right side of frame it was small and now stretched to center .
can i get solve to my problem ?
Sample :
Best Wishes
Ahmed Basha
10-04-2019 08:32 AM
10-04-2019 11:12 AM
@Waddizzle wrote:
What camera did you use? What exposure settings did you use? Specifically, what were your shutter speeds?
What was your White Balance setting? I do not see what you are seeing.
It shows up fairly clearly on my monitor. A wild guess would be a light leak through the viewfinder.
10-04-2019 01:18 PM - edited 10-04-2019 01:20 PM
@RobertTheFat wrote:
What was your White Balance setting? I do not see what you are seeing.It shows up fairly clearly on my monitor. A wild guess would be a light leak through the viewfinder.
I was using the iPhone. You can only zoom in so much.
I suspect the "blue" is simply hazy atmosphere.
Besides, the image is more OOF than hazy or blue.
10-04-2019 02:12 PM
canon 5d mark iv and the settings was ( Shutter speed 30" , ISO 230 , f/7 , 16mm , WB : K5200 )
10-04-2019 07:00 PM
@ahmedbasha wrote:canon 5d mark iv and the settings was ( Shutter speed 30" , ISO 230 , f/7 , 16mm , WB : K5200 )
Your shutter speed is too slow.
With an ultra wide angle lens, you really do not need to stop down the aperture to get a deep depth of field. You can focus to the hyperfocal distance at 16mm, and get the entire scenes in focus, especially the shot overlooking the city at night.
There is so much wrong with these shots that I do not know where to begin. For example, I have never heard of ISO 230 before, so I guess that is a typing mistake. Overall, your posted settings do not make any sense.
I think you need photography lessons. A DSLR is an instrument that creates photographs. If you want snapshots, then use your cell phone. Like any instrument, it takes time and practice to learn how to use it effectively.
10-04-2019 02:08 PM
I used canon 5d mark iv and the settings was ( Shutter speed 30" , ISO 230 , f/7 , 16mm , WB : K5200 )
the problem with all photos i taken by the lens at any time
Example
Thank for caring
Ahmed Basha
10-05-2019 06:59 AM
@ahmedbasha wrote:I used canon 5d mark iv and the settings was ( Shutter speed 30" , ISO 230 , f/7 , 16mm , WB : K5200 )
Example
Thank for caring
Ahmed Basha
The resolution is 400 x 267. File size is 35 kB. These are just two reasons why your images are not sharp.
10-05-2019 12:02 PM
"My first thought is user error."
I'm sticking with my first thought. You need to learn how to use the camera or let someone else do it.
10-05-2019 12:42 PM
@ebiggs1 wrote:"My first thought is user error."
You may very well be right. But the diagnosis isn't particularly helpful unless you can at least provide a plausible speculation as to what that user error might be.
