prime lens
kertl7779
 I only use a 70-200 f2.8L IS II USM telephoto lens to take baseball pictures, however, I am going to be taken players portrait pictures. I need advice of which Canon prime lenses I should choose for my Canon 60D camera. Thank you
7 REPLIES 7
cicopo
35 mm or 50 mm should do nicely.
hsbn
Whiz
You don't have to spend money for Prime Lens, the 70-200 F2.8L IS II is great for potrait. Unless you really want to get a prime lens, then the 85 F1.2L,  or 135 F2 are highly recommended lens by potrait photographer. For me, I think your current lens is already really good.
Weekend Travelers Blog | Eastern Sierra Fall Color Guide
Keep in mind it's a crop body so the 50 acts like 80 mm.
then the 35 mm will be the best choice, thanks
Thanks for your suggestion. If that is the case, it will work for me. I don't have to change lenses all the time.
ScottyP
As Cicopo says, on your crop sensor 60d, you would do well with a 50mm or an 85mm length. This is because the "classic portrait length lens" is 85 to 135mm on a full frame sensor. On the 1.6x crop bodies, you therefore are looking at a 50mm or 85mm. 135 would be awfully long.
If your baseball portraits are of the full-body, holding a bat variety, you will want to stay down at the wider 50mm length or you will have to stand back a long way to get the whole body in.
That said, you already own a really great portrait lens in your 70-200 f/2.8. See below:
http://www.the-digital-picture.com/Canon-Lenses/Canon-Portrait-Lens.aspx
Good luck!
Scott
Super info, thanks
Enter for a chance to win!
April 20th-28th
