Reply
Occasional Contributor
Accepted Solution
my 400mm 5.6 wont focus sharp
Hi Guys
Appreciate any help here
I have my camera  (5d mkiv) set up on tripod and trigger with my 400mm lens. It is set up as one shot with the center focusing point. I take a picture in live view at 25m and it is pin sharp, however when i use normal position it is not as sharp, I have gone thru the micro settings from -10 to +10 but still cannot get it as sharp as live view. Any suggestions would be most welcome
VIP
Re: my 400mm 5.6 wont focus sharp
"... it is pin sharp..."
This tells you it is not the lens or camera.  That means you need to look elsewhere for the issue.
Esteemed Contributor
[ Edited ]
You need something like an AlignRite - or a yardstick at 45 degrees - to tell *where* it is focusing.
If it is severly front/back focusing, you can send it to Canon to be calibrated with your camera.
Does it Focus OK with other lenses?
Honored Contributor
[ Edited ]
When you focus using Live View you are looking at excatgly what the sensor is recording. If its in focus in Live View it will be in focus in the digital file.
When you are focusing through the view finder you are indirectly focusing the lens; you cannot actually see whether it is in focus or not.
If its "pin sharp" in Live View but not when you use the "normal" AF system it means there is a problem in the phase-detection AF system "flowpath". It could be badly out of adjustment or damaged, so that camera repair is necessary, or it could just need autofocus micro adjustment "AFMA".
https://cdn.static-bl.com/images/manual/Canon-AF-Micro-Adjust-Guide.pdf
1D X Mark III, Many lenses, Pixma PRO-100, MX472, LR Classic
i have not tried it with other lens, but will do - thank you
It is a brand new camera so I hope that isnt the issue. Could it be the mirror action that is sending it slighty out
Honored Contributor
With only one lens and camera yo cannot isolate the problem. Need to get an additional item and then see what happens.
VIP
"This tells you it is not the lens or camera.  That means you need to look elsewhere for the issue."
My intention was to confirm the lens and camera can be "pin sharp".  That is why I suggested the OP look "elsewhere".
You mentioned using center focusing point and getting a sharp result.
But then you said "i use normal position it is not as sharp".
What's "normal" position?
Are you referring to a different focus mode?  Different focus points?
In "One Shot" mode the system only focuses until it achieves focus... then stops focusing.  If anything moves after it achieved a focus lock, it does not re-focus unless you force it.  In "AI Servo" mode it will continuously track focus.
As for focus points... if you force it to use a specific AF point, then that's the point it will use (you can also use AF point expansion or surround modes to increase the area, but again... it will stick to that cluster of points).
If you start to give the camera more freedom ... zone focus or allow all AF points... then the camera uses some rules to decide how to choose a focus point.
In typical One-Shot mode (if all AF points are active), it will typically try to find the AF point that can achieve focus at the CLOSEST focus distance to the camera.    This means you would want to make sure there is are no focus points located on anything in the scene which is closer than your intended subject.
In AI Servo mode it will follow the rules based on the intelligent Tracking & Recognition system (iTR).  You can do things such as set an initial point of interest and then select the "case" rule for how it should behave when trying to follow that subject around the frame and it will do its best to keep up.  It will typically highlight (with a few squares) the points that are being tracked so you know what it thinks it is focused on.  There are also rules about how it should behave when doing a burst of shots.    Note that iTR is only active in viewfinder mode (not available if doing live-view) and also you must be using either zone-AF, large-zone-AF, or full auto-AF (all points active).  It is not available if using spot, single-point, AF-expansion, or AF-surround modes.
If single-point AF nails focus for you... then my guess is when you say "normal position" you are letting the camera pick the AF point and when that happens, it has different rules to decide which AF point should be used.  This isn't a big deal if you know the rules.
Tim Campbell
5D III, 5D IV, 60Da
sorry for not explaining myself better.
So I took a picture of a static object with small lettering on at a distance of about 25m. the 1st picture was taken in live view. This was sharp and lettering was crisp.
I then took a picture through the view finder with the single center focus point selected, it was in one shot mode. this produced a picture with blurred lettering.
I went 10 points both negative and positive microadjustment, I did get a slightly more foccused lettering but not as good as I got in live view
powered by Lithium
