07-04-2016 05:41 PM
my 15-55 mm lens is hard to turn to adjust it also the auto focus isn't working any suggestions. Should I try to get it fixed or would it be best to just get another lense. I saw some used ones that seem pretty reasonable
07-04-2016 07:37 PM - edited 07-04-2016 07:38 PM
Could this be an 18-55 lens?
What camera body do you have?
07-04-2016 09:23 PM
yes, sorry. 18-55 it's a Rebel 5T.
07-04-2016 11:13 PM
It would make no economic sense to repair a kit lens like the 18-55. Are you sure the lens is bad and not the camera? I'd try another lens to be sure.
07-05-2016 02:13 AM
I already tried another lense. It works fine.
07-05-2016 04:38 AM
Try this:
07-18-2016 08:40 PM
well, this worked. the ring that changes the mm isn't changing easily, I have found that if I turn the focus ring, it will then let me adjust it. Otherwise it stops. but the auto focus is working again. Thanks for your help.
07-19-2016 08:05 AM
Do not turn the focus ring when the AF/MF switch is set to AF.
