10-09-2016 09:30 PM - last edited on 08-30-2022 09:21 AM by Danny
My efs 18-135 when zooming out wide to 18mm or going to the other end135 stops autofocusing the green dot light circle does not come on,when you try turning the zoom it clicksand locks and you have to use a little force to make the lens move.there is no problen when I use manual focus The lens works intermittingly and its not the 60d camera that its on I use another efs canon lenes which works fine.
10-10-2016 07:00 AM
Did you bump the lens? When it is fully zoomed out does the lens barrel look crooked compared to the non-zoomimg part?
10-10-2016 12:54 PM
No the lens was not droped, or crookedbut i do here something loose inside like a tiny screw or piece of plastic when you shake the lens up and down jently. it will work fine for awhile then act up when you try to zoom out all the way to 18 orgo in to135 then it locks up when you try to turn the barral it rachet clicks and doesnt want to turn, you have toforce it that when you here the clicking noises and it wont auto focus. Iswitch the af button to manual focas and iget the green dot that it is manually focased and I then can snap the picture it always works fine in manual, the problem is when its in af focus I can take 20 -30 pictures in af then it acts up then I have to go back to manual. Thanks
10-10-2016 01:14 PM
One other thing when the efs 18-135 is in autofocus is the focus ring supposed to turn smoothly or I shouldnt be trying to do this this way because its tighter to turn and I here the racheting when I try to turn it when I switch the button to manual its smooth and no rachiting and it works
10-10-2016 02:08 PM
@photobug49 wrote:One other thing when the efs 18-135 is in autofocus is the focus ring supposed to turn smoothly or I shouldnt be trying to do this this way because its tighter to turn and I here the racheting when I try to turn it when I switch the button to manual its smooth and no rachiting and it works
If the lens does not allow manual focus override (see Waddizzle's last note), you may damage the lens by turning the focus ring with the lens in autofocus mode. With some of the 18-55 kit lenses there's a procedure that sometimes lets you manhandle the lens back into working order. Whether something similar would work on the 18-135, I don't know. I've never seen it recommended.
10-10-2016 10:07 AM
@photobug49 wrote:My efs 18-135 when zooming out wide to 18mm or going to the other end135 stops autofocusing the green dot light circle does not come on,when you try turning the zoom it clicksand locks and you have to use a little force to make the lens move.there is no problen when I use manual focus The lens works intermittingly and its not the 60d camera that its on I use another efs canon lenes which works fine.
Exactly which EF-S 18-135mm are you using? I'm not sure if they all allow manual focus override. Make sure AI Servo is not engaged when you try manual focus override, too.
I have used the STM version, and AF would sometimes get lost when I made large changes in focal length.
