08-18-2016 09:09 AM
Will a Canon 60d lense work with a Canon T6i?
Thanks
08-18-2016 09:19 AM
Yes, both use EF *and* EF-S lenses.
08-18-2016 07:58 PM
They have exactly the same lens mount.
08-19-2016 09:32 AM
almost all lenses EF work on both cameras ( full frame and apsc) but some EFS work only on apsc cameras. EFS is for croped sensor (mostly).
and one important thing: apsc is cropped sensor, so if you have prime lens Ef 50mm f1.8 on full frame, that lens will act like 80mm f2.88 on apsc camera (multiple with 1.6).
08-19-2016 09:50 AM
@Milos1978 wrote:almost all lenses EF work on both cameras ( full frame and apsc) but some EFS work only on apsc cameras. EFS is for croped sensor (mostly).
All EF-S will only work on crop frame cameras, not "some".
08-19-2016 10:31 PM
"... that lens will act like 80mm f2.88 on apsc camera (multiple with 1.6)."
I know the debate and arguments made for a 1.6 change in aperture but I, among others, do not think it is valid. The physical specs of a lens can not change. You must insert the word 'equivalent' or 'appearent' difference. A 50mm f1.8 is a 50mm f1.8 and will always be a 50mm f1.8 lens.
08-20-2016 08:55 AM
@ebiggs1 wrote:"... that lens will act like 80mm f2.88 on apsc camera (multiple with 1.6)."
"Good lord, you guys really need to stop detailing a post to the last degree."
08-20-2016 12:59 PM
If it makes any difference, I doubt it, but that statement was in reference to your lack of comprehension of my reply. This "act like 80mm f2.88 on apsc camera" is incorrect. Big difference and I hope you grasp it.
