06-12-2013 06:36 PM
06-12-2013 06:49 PM
Hi Andyzem
To have a better understanding of your issue, please let everyone know which model camera you are using with your lens. That way, our Canon Forum members and our Subject Matter Experts will be able to assist you with suggestions appropriate for both the lens and camera.
Additionally, have you tried mounting the lens to a different camera body? If so, do you still have focusing problems? Does your camera focus correctly with other lenses?
Thanks!
06-13-2013 11:48 AM
This happens when you (and the lens) is trying to focus at or closer than the minimum focus distance (MFD). The AF and manual focus will drive it there and it appears to be in focus for a moment but drifts out of focus. I notice that other lenses don't do this - you simply can't get focus. This lens does for a fraction of a second. I learned to use this to great effect...you just need to be quick.
06-13-2013 04:12 PM
I also own this lens and use very frequently for taking macro shots. It is easy to be closer to the subject than the lens is designed for, about 11 inches. Actually, when shooting things like bugs it is within the bug comfort range, and the subject flys away before you can shoot. To be able to get closer than the minimum focus distance you can add one or a series of extension tubes. These tubes actually extend the mm of your lenses lenth by a precise amount. This does not give you any more magnification, but allows you to photograph with your 100mm macro lens closer to the subject than the minimum focus distance. These tubes are placed between the body of the camera, and the lens. The tubes are hollow, and have no glass installed in them. Some tubes do have electrical connections to the body of the camera and lens through the tubes. This allows the auto focus to operate. You may have to manual focus a touch to achieve pin point focus on the subject. But the outer element of the lens will be much closer to the subject. Canon makes these tubes, but you will pay a high price for them. Sets are available from third party companies like Kenko, which are very good. The set includes 3 tubes, in various lenths, my set has 31mm, 21mm and 13mm, and will allow the electronic focus to function. I hope this information is helpful. The Canon EF 100mm 2.8L IS USM is one of their best lenses.
