Which Lens? Strange Application
MattBaugh
I stream board games and am looking to upgrade my overhead shot.
I need to keep a 44" x 60" area in frame (roughly a 4:3 aspect ratio) with minimal parallax at the edges. I can place the camera 4-5 ft above the play surface with a normal C-stand/overhead set up.
I have a Canon M50 and am considering an M200 because the size seems good for an overhead rig.
Any suggestions on what lens would produce the best results for these cameras? Still very new to all of this.
Thanks so much!
Matt
For 25mm, that would force you to put your camera 6 feet 3 inches away.   As I mentioned earlier, for the maximum distance being 5 feet, you'd need 20 mm or wider to fit everything (i.e. 18, 14, etc.).
Ricky
Camera: EOS 5D IV, EF 50mm f/1.2L, EF 135mm f/2L
3 REPLIES 3
rs-eos
Assuming I did things correctly, at that distance (I used 5 feet), you'd need a 20mm or wider lens on the APS-C sized senor in the M50.
I used 3D software to set up a camera with sensor size width of 22.3 mm, a gray rectangle of 60 x 44 inches, and the camera at 5 feet away:
The result (I output to a 3:2 aspect ratio) is:
That wide angle lens (field of view as if it was a 32mm on your camera) would distort near the edges.  How much, I don't know.  But your only other options would either be to use a standard/short-telephoto lens, but have the camera much further  away.   Or, move to a full frame camera.   At a distance of 5 feet, you could then use a 32mm focal length).  For 35mm, the distance would need to be around 5 feet 5 inches.
Ricky
Ricky,
Thanks for your amazing response!
I'm still very new. I'm not saying I am going to buy this lens, but would this be an example that would fit what you've describe? a 25mm wide angle lens?
https://www.amazon.com/Neewer-Aperture-Compatible-Mirrorless-Cameras/dp/B083SMLSCW/ref=sr_1_3?dchild...
Thanks,
Matt
Ricky
Enter for a chance to win!
April 20th-28th
