05-16-2014 05:18 PM
what size filter will fit canon EFS 18-55 mm lens?
05-16-2014 08:04 PM
Canon usually puts the filter size on the ring on the front element or somewhere along the side. It'll use the diameter symbol ⌀. That lens is 58mm. Though I usually find Google to be fastest for such questions:
http://www.lmgtfy.com/?q=filter+size+ef-s+18-55
05-16-2014 08:56 PM
thank you..i got a Tiffen 58mm circular polarizing filter . initially i couldn't t it to fit.
10-28-2016 09:56 AM
10-28-2016 10:05 AM
@nirjan169 wrote:
@dsomers56 : Is that 58 tiffen filter working good with 18-55 lens?
Some of the EF-S 18-55mm lenses rotate the front element to focus. For a CPL filter, which relies upon rotational orientaiton to be effective and useful, a rotating lens is problematic. Better lenses focus internally, without rotating the filter ring threads.
10-28-2016 10:26 AM
@Waddizzle wrote:
@nirjan169 wrote:
@dsomers56 : Is that 58 tiffen filter working good with 18-55 lens?Some of the EF-S 18-55mm lenses rotate the front element to focus. For a CPL filter, which relies upon rotational orientaiton to be effective and useful, a rotating lens is problematic. Better lenses focus internally, without rotating the filter ring threads.
There are, of course, many lenses that don't focus internally but still don't rotate their front elements.
10-28-2016 12:06 PM
10-28-2016 12:43 PM
@nirjan169 wrote:
Still the filter will be fit with the lens,right?
A 58mm filter should almost certainly fit. If you gives a brand name and part number, we could tell you for certain.
10-28-2016 01:09 PM
10-28-2016 01:46 PM
@nirjan169 wrote:
I have canon Rebel t5 and I am using 55-250 zoom lens. So, is the lens compatible?
Yes. There have been a few variations of the EF-S 55-250mm lens, as well as the EF-S 18-55mm camera kit lenses, but I think they were all 58mm. You should note the complete model number of the lenses, and consult your vendor to be certain.
