04-23-2013 01:54 PM
What is the best lens for shooting fireworks and why? I have the 10-22 that one of your associates recommended.
04-23-2013 01:57 PM
Any lens can be used to shoot firework. It's not about gears. Even point and shoot camera can shoot firework. But you would need a moderate wide angle lens if you want to capture the scenic also. Your lens work great.
04-23-2013 02:00 PM
I don’t think fireworks are a lens specific thing. It depends entirely on your desired composition. I like using ultra-wides myself and have had success with the 10-22, but that’s just because that was the composition I wanted. Others may use a zoom lens to get in close.
For fireworks I usually use mid-sized apertures, so you don’t need a fast lens. Obviously the sharper the better, but it doesn’t have as much an importance as something like a landscape shot as the majority of your frame is black space. So really, and lens is fine.
04-23-2013 05:53 PM
Lens won't be as important as settings. Try different shutter speeds to see which effect you like.
04-24-2013 11:52 PM
You will also need a nice Tripod and a remote switch to avoid camera and hand shake since you be using longer shutter speed and smaller aperture.
