02-01-2016 09:40 AM
Hi everyone,
I have been working with a Canon 60D and a 18-135mm Canon lens. When I need to photograph interiors and need different expositions, I measure light in different zones, put my camera on a tripod, focus where I want and turn the auto focus off. I take one photo then I only change the speed and take the second one. I don't know why but the second photo is slightly different, just several milimiters changed relatively to first photo position. Am I doing something wrong? I have been googling it but didn't find anything. This lens is 4 years old. Is it possible that is due to lens wear?
02-01-2016 10:09 AM
@rubensantos wrote:Hi everyone,
Try using an remote shutter release and use the camera's 'exposure bracketing' feature so you don't have to touch the camera between shots.
02-01-2016 12:43 PM
Yeah, you are moving the camera. You need the remote shutter and turn on bracketing in the camera.
02-01-2016 12:54 PM
You are suggesting when I change speed I may change camera position. It makes sense, thanks.
02-01-2016 10:09 AM
02-01-2016 12:54 PM
02-01-2016 02:19 PM - edited 02-01-2016 02:21 PM
And if you don't have a remote shutter release you can just set the 2 second delay in shooting mode. That way even if pressing the shutter button makes the camera shake, it will have settled down and it is still 2 seconds later when it takes the picture.
That at plus bracketed shooting and you should be ok.
02-01-2016 12:43 PM
02-03-2016 12:19 PM
If your lens re-focused between shots then you may be noticing the effect of lens "breathing". Altering the focus elements in a lens will very slightly alter the angle of view (focal length) of that lens. For some lenses this is very significant... for other lenses the effect is quite significant.
To avoid, after focusing the lens, switch off the auto-focus feature (the AF/MF switch on the side of the lens) to avoid refocusing between shots.
02-03-2016 12:28 PM
I have explained that in the text above.
