Reply
Reputable Contributor
Re: Ultra-wide angle zoom question
I got a little different result with Ebiggs using Auto Giga Pano software. But it could be due to the files are small.
Weekend Travelers Blog | Eastern Sierra Fall Color Guide
Occasional Contributor
No, the camera was on a tripod.  The only part of the ball head that was loosened was the horizontal function, which was tightened before each shot.  As I mentioned earlier, PhotoShop Elements managed to stitch 4 of the 5, but the missing one was in the middle, making the image worthless.
The file sizes ranged from 3.49 mb to 3.61mb. Your result appears to have produced the correct breadth of the panorama. However, it looks to me like part of the clouds are a bit low. Also, I'm not sure that the files as posted are the same resolution as my originals.
Respected Contributor
If you want HDR you should do each "frame" in HDR first, then stitch.  But for something that simple I'd just "stitch" it by hand.
Open in Elements
Expand the canvas size (little on top and bottom, a lot on the sides)
Import the other shots
Move them around until they look good
Mask each layer and use a soft brush with low fill to blend the layers into each other
I would also create a curves adjustment layer for each layer, turn it into a clipping mask (Ctrl alt g) so it only affects the layer below, and you can fine tune your exposure to make sure they match.
Forum Elite
Something changed because the post of the dock(?) is not the same size in each frame.  Neither is the clouds in the back ground. Unless you didn't size them evenly when you uploaded them?
I need to respond to a couple of issues brought up:
1)HDR - the hdr function was completed at each shot.  In this function the shutter triggers 3 times; one at each of 3 exposure settings, then the camera processes the three into one frame.  While the camera is processing the image(s) the camera is not available for another exposure.  For all shots, I used a Canon cordless remote control .
2) Size of dock pier post - the exposures I posted are the original frames; thus no post camera processing on them.  The post was only a foot or two from the camera which might explain the size error or distortion.  But I have no clue re clouds.
As I mentioned earlier, I do not remember what focal length I used; however, it may very well have been at 17mm.  Notice how distant the scene is of the resort skyline.  I do remember that the scene as viewed thru the live screen appeared a bit distorted or stretched.
For the record, I took several sunrise shots (at the ocean front from a balcony) with this lens on successive days previous to this panorama attempt.  They were not taken to stitch, but just individual shots.  They turned out quit satisfactory.  I even got the moon and sun within the frame, but of course the moon looked way to far away.  In any case, no distortion.
Hope this clears up some of the questions.
powered by Lithium
