08-12-2018 01:06 PM
I use an older Tokina 28-70mm f/2.8 ATX Pro (not the SV model) which I love. However, the camera's EXIF data recognizes this lens as a Canon 28-70mm f/3.5-5.6. How can I change the EXIF to read the correct lens or to read no lens at all rather than the incorrect model?
08-13-2018 11:15 AM
@ebiggs1 wrote:"A third possibility, much less likely than the other two, ..."
Glad you opined, "much less likely", Robert because that is nonsense.
Well, I'm not sure I'd go so far as to call it nonsense, but it does presuppose an unlikely degree of carelessness in how Canon identifies their lenses to their cameras. It's certainly an odd situation, and it will be interesting to learn what the OP is able to determine if he runs some tests.
08-13-2018 12:05 PM
Robert you make the case for nonsense with your own answer. I can imagine some legal problems if that idea was intentional.
