06-10-2021 06:56 AM - edited 06-10-2021 08:20 AM
For some time I have been having issues with my standard kit 18-55mm Canon lens on my Canon 600D camera. Normally when fully extended or contracted, the autofocus works fine but when partially zooming in or out, the autofocus will not work and the screen just flashes. There is no attempt by the lens to focus (no sound or movement) and the screen just keeps flashing. With my 75-200mm lens the autofocus works fine and like I said, works ok on my 18-55 lens when on 18 or 55mm but not when partially zoomed.
06-10-2021 08:13 AM
Hi, karlcanaries!
So that the Community can help you better, we need to know exactly which Canon camera model you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
06-10-2021 08:21 AM
OK thanks, I edited the post stating the camera model.
06-10-2021 10:02 AM
Try this:
If this doesn't work it needs professional service. Call Canon 1 (800) 652-2666
