Reply
Highlighted
New Contributor
Accepted Solution
Removing scratches from front lens?
I have a few small (light)scratches on the outside perimeter of my 18-135mm lens. I really do not see a problem with my images. But how do i remove them. Some recommend toothpaste, others very fine sandpaper 4000 etc. If use of toothpaste is recommended with sodium bicarbonate or without, with fluoride or not etc. And some recommend a water isopropyl mixture which i tried and did not work.. Thanks for your help!!
Highlighted
VIP
Re: Removing scratches from front lens?
Do nothing. As long as your images are unaffected I would ignore it.
Highlighted
Honored Contributor
Agree. Since you can't see any impact of the scratches you won't gain anything by trying to remove them.
And you run the risk of creating damage that you will see.
1D X, Rebel T5i, Many lenses, Pixma PRO-100, MX472, LR Classic
Highlighted
Reputable Contributor
Anything you do is going to make it worse.  The lens likely has a coating and anything you do to remove scratches is likely to turn what is currently a non-problem (if the current images are acceptable) to something that is very noticeable.
Those glass scratch remover "kits" using some form of abrasive compound (includes toothpaste) are intended for removing cosmetic scratches from glass and not to "fix" optical glass.  I restore vintage ham radio gear and have used various light abrasives to remove cosmetic defects from meter and dial glass but images aren't being taken through that glass.
Anything beyond proper cleaning of lens elements will range from doing nothing to turning a minor issue into a major issue.
Rodger
EOS 1DX M3, 1DX M2, 1DX, 5DS R, 1D M2, EOS 650 (film), many lenses, XF400 video
Highlighted
Agree with the other posters.  You have the scratches and it's too late to do anything about them.  If you seriously run the risk of getting more then put on a good quality protective filter.   I know this is a cause of much debate and people take positions, but the fact remains that if you had one on you would not be worrying about the scratches you now have.
cheers Trevor
"All the beauty of life is made up of light and shadow", Leo Tolstoy;
Highlighted
New Contributor
the scratches were created by me when dismantling the front lens to clean the dust etc off the inside of the lens. I was successful. ugh!!
Highlighted
Honored Contributor
It's OK to practice on crappy lenses that you don't care about. But IMO nobody without professional experience in camera repair should disassemble a good lens.
Bob
Highlighted
VIP
[ Edited ]
I agree with Robert, the lens is probably ruined.
Highlighted
I guess that is lesson learned - the hard way. Smiley Sad
I would never take a lens apart.  Apart from the possiblity of damage, unless you have a clean room then you have an excellent chance of getting more dust further into the lens.  I hate dust but also realize that it is more cosmetic than anything. It would have to be massive and I mean MASSIVE to have a significant impact on your images (unlide sensor dust).  Finally you likely don't have the tools to ensure the micro level precision required to make sure the elements are perfectly aligned.
If the lens still works and produces sharp images, good for you and consider yourself very fortunate, but I would avoid further forays into that area.
cheers Trevor
Highlighted
New Contributor
Trevor, as per your advice i will leave any lens repair up to the professionals. Thanks for your tips!
powered by Lithium
