Reply
Occasional Contributor
Accepted Solution
RF 24-105mm f/4L IS USM lens slightly wobbling
Dear community:
The top portion of the lens is wobbling a little bit from side to side due to an unexpected drop to the floor. I checked and the lens is working fine. manual mode and AF mode work fine. Should I send it to service or do you think I can live with it? Thank you
VIP
Re: RF 24-105mm f/4L IS USM lens slightly wobbling
"Should I send it to service or do you think I can live with it?"
Yes by all means.
Any dropped lens or camera needs attention.  There can be and likely is hidden damage indicated by, " the lens is wobbling a little bit from side to side...".  Lenses are critically aligned equipment. Dropping that appears to have no damage can alter any or all those critical alignments. Send it in and explain it was dropped.
Thank you ebiggs1, yes, I did, I sent the camera and lens to the canon center in Costa Mesa, CA. Thank you for your advice.
powered by Lithium
