12-28-2015 08:49 AM
Extender EF 2x III - or the EF 1.4x III. Same price. Other than the obvious, why one over the other? Are the optics equal?
Thanks!
12-28-2015 10:51 AM - edited 12-28-2015 01:41 PM
And of course this is the correct answer....
"I would recommend the 1.4X if you can only afford one.
I'm sure you probably know this, but the Canon extenders only work woth with certain Canon lenses ..."
In general extenders are a poor idea. You give a lot to get little. There are a few "L" lenses that tolerate an extender fairly well. Most lenses don't. The Canon EF 70-200mm f/2.8L IS II USM Lens and the Canon Extender EF 1.4X II work well together. I have this combo so I can recommend it. It also works well with the Canon EF 300mm f/4L IS USM Lens. Again a personal tested combo, I can recommend it. As a general rule they don't and you should avoid lenses that are slower than f4 with an extender. And f2.8 is even better. And again, IMHO, avoid the 2x altogether.
Then you get into the really super tele like the Canon EF 500mm f/4L IS II USM Lens. Although the 1.4x works OK with it, it brings some more difficult limits to over come. At a 700mm FL, it can be quite a challenge to use. I do not own that combo but I have rented it.
01-04-2016 06:46 PM
@jrhoffman75 wrote:
Don't bring enlarging into it. A properly exposed negative is a properly exposed negative.
If theAPS-C digital sensor needs more amplification to expose properly at a given ISO, f/stop and shutter speed compared to full frame how didAPS-C film accomplish that?
You have to bring enlarging or scanning into it, because getting a negative is only half of the processing. It would be like exposing the sensor on a digital camera and never having it process and write it to the memory card. You have to take the complete film process from the time the photo is taken, till the time you have usable output, or it isn't an analogous comparison.
