Reply
New Contributor
My 50mm 1.4 is stuck at 1.4
My canon 50mm 1.4 lens is stuck at f/1.4.  The image is identical from 1.4 all the way to f/22.  I don't know why this is happening.  Any ideas?
Respected Contributor
Re: My 50mm 1.4 is stuck at 1.4
Do you mean the camera reads whatever aperture you set? What do you mean the image is the same all the way to f/22? I can see the DOF staying the same if the aperture was frozen, but how is the image not overexposed if the camera thinks the lens is stopped down to f/22? Unless you were shooting Manual, it seems like the camera would be slowing the shutter to give a correct exposure for f/22, which would overexposed the shot with the lens really open to f/1.4.
Scott
Forum Elite
"My canon 50mm 1.4 lens is stuck at f/1.4."
You have it set to Av mode.  Switch back to the green square.
Perhaps the OP will elaborate on which mode he is in, and what the camera and lens are doing.
Scott
New Contributor
Sorry for not giving enough info.  I first tested the lens on a t3i when I discovered the problem.  I then switched to a 5Dmkii to see if it was the camera but I had the same issue.  I was in video mode on the t3i and manual on the 5D.  It seems like the lens won't move from f/1.4 even thought the cameras read at different f stops.
Why would you use the green square if you were trying to get a different aperture?  Av is exactly the mode I'd use - or manual.
If you begin recording at a different aperture does it look like it's shot at that aperture or still 1.4?  If you're on manual and just change the aperture then does the exposure dim?  Can you change the aperture for stills?  Sorry, don't know much about video, but that's where I'd start my trouble shooting.
Forum Elite
[ Edited ]
"Why would you use the green square ..."
By mistake!  Smiley Surprised
New Contributor
No matter what I do the aperture doesn't change.  I've shot with the lens/camera for over 3 years and this is the first time I've had a problem like this.
Forum Elite
I think yiu have answered your own question, it is broke. Smiley Sad
powered by Lithium
